ok guys i have a 1992 Ford F150 with a 5.0L 302 and a AOD transmission and 180,000 miles on it. A month ago i was driving home from college and i turned down a road the truck all of a sudden had no power barely any to pull itself up a hill. Upon further inspection the trucks exhaust manifolds were glowing orange so this means it was running extremely lean on both banks. so when i got it home i pulled the distributor cap after checking to see if it had any spark because it wouldnt even turn over. the truck was not sparking and when you went to crank it up the motor would turn but the rotary button was not. so i pulled the distributor and it sheared the pin holding the timing gear in place. the distributor that was in it wasnt even a year old so i got a new one with the warranty we re installed it put the truck on top dead center re stabbed the distributor and placed it where the rotary button was on cylinder 1. replaced all the spark plugs etc. we took the chip out that runs off the modual (fender mounted) that is suppose to be removed to retime the vehicle. when we went to start it to retime it to 10 degrees with the timing light the truck turns over but will not start. fuel pump kicks on and is running at the right pressure and the coil is sparking but the truck will not start. we rechecked everything and its all where it should be. this is where i need help WHY WONT THIS THING CRANK. It has good compression on all cylinders to any help would be appreciated.
we took the spark plug out of cylinder 1 and placed a finger over the hole until the motor turned over on compression stroke and blew it off of the hole.
No we didn't try moving it around while starting. And I will check the spark to the plugs. I'll post back when I do. I have to work on it outside I don't have a shop or garage and its cold as heck and suppose to start snowing tomorrow.
