Broke off screw in throttle body
Hey all,
Just wondering if there's any other solution than buying another throttle body for my Ranger,1999 2.5. I was replacing the idle air control valve, and the bolt broke off in the throttle body. I tried various ways to get it out. Long story short, that screw hole is out of commission. Can you replace it with just one screw or some other way to rig it?
Thanks for any suggestions.
Steve
Steve
IAC
But how do this get the screw out? I broke out one and is wondering how to get the screw that is broken under the IAC
HI if the screw is not bottomed out and the head is gone there is really nothing holding it in except gunk. So if you can remove the rest of the part you should be able to back the screw out easily by hand or with a reverse (left handed) drill bit if it is below the housing..
good luck take care be safe
tim
tim
kailor
1997-2006 Expedition & Navigator
01-10-2008 09:32 AM
MustangGT221
05-09-2005 02:48 PM
