Distributor Won't Turn
Old 02-06-2016, 08:45 AM
treverd's Avatar
treverd
treverd is offline
1971 F100 Stock 360
Started truck up and got it to operating temp and turned it off.
I was bumping my starter over to check the points gap. Bumped it once and then bumped it again. On the second one the distributor wouldn't spin.
Now all I hear is something spinning very quickly, but the distributor doesn't turn.
Oil Pump seized?
Timing Chain Broke?
What's your thoughts?
Old 02-06-2016, 08:47 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Have you pulled the distributor yet? I haven't had enough coffee yet to think, but there is a roll pin securing the helical gear on the distributor shaft. Maybe that sheared.
Old 02-06-2016, 09:11 AM
orich's Avatar
orich
orich is offline
if you hear something spinning real fast and engine not turning over then,
I'd pull the starter and check it. The gear that engages to the fly wheel ring gear may have failed.
Orich
Old 02-06-2016, 09:26 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
sounds like starter is not kicking gear forward , common starter problem
Old 02-06-2016, 12:33 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Well given what he wrote I get the impression the engine is turning over, but not the distributor. He would not know the distributor isn't turning over otherwise?
Therefore the issue is, everything is normal except the distributor rotor is not turning. He's asking the right questions.
Old 02-06-2016, 01:26 PM
treverd's Avatar
treverd
treverd is offline
You guys are awesome!
Pulled the distributor and everything looked great. Turned the motor over with a 15/16 socket on the crank. Looked down and saw both cam and gear moving.
Put it to TDC installed the distributor back on.
It's definitely the starter gear not kicking out to the flywheel. I gave the starter a few good taps with a mallet and no change. Still not engaging with the fly wheel.
I will be replacing the starter. Any specific vendor to look at or stay away from?
Old 02-06-2016, 02:41 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Well OK. If the engine won't turn over at all don't bother pulling the distributor!
I would probably try to satisfy myself the starter is actually bad. It's a judgment call too, how old is it, etc. Poorly grounded solenoid?, starter, cables, bad battery etc. I like to couple a new starter with a new solenoid. New as in NOS, not the el-cheapo chinesium schitt out there today. Probably a new Bendix starter drive as well. And some new starter cables - and and.. ...
Old 02-06-2016, 06:10 PM
orich's Avatar
orich
orich is offline
Hard to say any more what's good any more. Who ever gives you the longest warrantee. I guess it is about all you can do now days. Or take it to a loco rebuilder.
The solenoid is working if it's engaging the starting motor to spin it over.
It could be better then a Chinese make ones that may be all you can find in the loco auto parts stores.
Orich
Old 02-06-2016, 06:17 PM
orich's Avatar
orich
orich is offline
Something spinning fast with nothing moving was the tip off for me! NOT NORMAL.
Orich
Old 02-06-2016, 07:11 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Yabut, "fast" means different things depending. Even the title, the reader assumes the dizzy is the only thing that ain't spinning. He mentioned the rotor didn't turn,but neglected to mention the motor itself didn't turn over! No worries mate, tho clear communication always helps.
Old 02-06-2016, 10:49 PM
orich's Avatar
orich
orich is offline
Bottom line he's on to the fix, and hopefully it's just a starter replacement then he's on his way to happy motoring once again.
Orich
Old 02-07-2016, 04:19 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Is it just me or does it seem a little odd that the only way you can tell your engine isn't spinning over is because the distributor isn't turning?
Old 02-07-2016, 08:33 AM
Alex from GA's Avatar
Alex from GA
Alex from GA is offline
It certainly does Ollie. But I wasn't going to say it.
Old 02-07-2016, 08:51 AM
orich's Avatar
orich
orich is offline
That big propeller could do it if so equipped. Should odd of do it
Orich
Old 02-08-2016, 04:48 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
Orich, that's the first thing I ALWAYS watch for!!!
Quick Reply: Distributor Won't Turn
