Help with 223 Damper Install - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Log In
Old 02-05-2016, 10:51 PM
Otis 54's Avatar
Otis 54 Otis 54 is offline
Otis 54 is starting off with a positive reputation.
My 223 has been rebuilt and I am ready to install the damper. Will any balancer installation tool work as long as the bolt diameter and thread size are the same? Could I rent one from AutoZone or do I need something special for the old engine? Thanks for your advice and suggestions. I do not want to mess this up!
Old 02-05-2016, 11:52 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a very good reputation on FTE.38 coupe has a very good reputation on FTE.38 coupe has a very good reputation on FTE.
Any installation tool with the correct bolt or stud should work.
__________________
Fred Mills
38 Ford coupe project
49 F-2 pickup
53 Ford Customline sedan
Oliver 77 row crop tractor
Similar Threads
"Death Wobble" on lifted 2002 F250 SD Jamessmith1 Super Duty & Heavy Duty 20 10-04-2015 04:49 PM
Lash by ear? 64rednwhite 1961 - 1966 F-100 & Larger F-Series Trucks 4 05-05-2015 10:14 PM
Looking for a Rebuilt Damper '64 223 64rednwhite 1961 - 1966 F-100 & Larger F-Series Trucks 9 04-13-2015 02:11 PM
Vibration damper removal 78Truckster 3.8 & 4.2L V6 0 10-09-2014 12:35 PM
Steering damper? HillBillyBuddha 1961 - 1966 F-100 & Larger F-Series Trucks 11 04-23-2014 11:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
