Reverse lights both quit working at same time
Sprayed the truck off tonight and I went to back out of the bay and noticed I didnt see any reverse light and usually its pretty bright because I have a tail gate light bar. Looked and nothing. Neither reverse light nor the tail gate rev lights work. I don't really know when this started but possibly just got the wires wet? I will trouble shoot the best I can tommorow when it's day light by starting with checking fuses then go from there. Obviously not just a bad bulb. Any suggestions on what to look for after that? Tail lights work fine on both sides and the tail gate bar
Yea its an automatic e4OD. Thanks. I'll check the NSS. I have already tightened those nuts under the steering column but not familiar with the neutral safety switch so I'll look into that. Not sure where it is. ? I vaguely remember that I think I had to re wire the tail and rev light wires to the new tail gate bar and I went through some decent mud holes. It blasted that all over the wires and packed the rear bumper so I'm thinking I need to check those wires for sure bc honestly I didn't do anything more than black tape them together and zip tie it to the hitch mount.
Manual/AOD/C6
E4OD
Lamps/Wiring
BadMoFo
27
09-25-2023 12:54 PM
EMD_DRIVER
17
03-22-2009 04:08 PM
