power door lock question
yes, I searched first... anyway, just got this 96 f150 4.9 5spd shortbed eddie bauer truck. the door locks acted very weird. locking and unlocking them selves, etc... I replaced the drivers switch and all was good, for a few days... now it doesn't work at all (drivers switch)
I have pulled it back off and tested it. checks good. continuity from center pin to correct outer pins (when switched each way) I have power at center blk/wht wire. when testing with switch in place, power is going thru as it should.
all the window switches work, the pass door lock switch locks and unlocks both doors fine. drivers side, nothing.
what do you think?
what do you think?
