WOT run....have some questions
I had the truck on the 80hp towing tune, I'll make another stock run tomorrow.
I just got the new up pipes and billet wheel installed with RR return. Used my boost pressure tester and have it 95% sealed, need to order some new spider boots, spent about 2hrs trying to get them to seal up.
I set my pids from tuglys post, and they read as follows, my concern is the IPR. All readings are from a 20mph to 70mph run. These are the max readings.
boost: 28.5 psi
Icp: 3668.5 psi
Ipr: 82.0
Fipw: 4.3
Ebp: 53.0
Map: 42.7
boost: 28.5 psi
Icp: 3668.5 psi
Ipr: 82.0
Fipw: 4.3
Ebp: 53.0
Map: 42.7
What are you using to get these readings, Torque Pro? If so, you can throw out the boost number, the PCM will defeul the truck very quickly if you don't have a boost fooler on the map sensor, and if you do and the map is reading 28.5 you have to get it calibrated better. Otherwise, max numbers don't tell the whole story. Can you post a graph?
on
boost: 28.5 psi
Icp: 3668.5 psi
Ipr: 82.0
Fipw: 4.3
Ebp: 53.0
Map: 42.7
boost: 28.5 psi
Icp: 3668.5 psi
Ipr: 82.0
Fipw: 4.3
Ebp: 53.0
Map: 42.7
You are correct, the IPRDC% is high, almost 2x, as is the ICP and FIPW. What kind of HPOP are you running...just curious. Was that the high point where the ICP spiked or was your HPOP maintaining that?
Make sure stock is actually stock when you make your run as long as you have your original split shots in there.
You should probably throw in RPM's and MPH into the graph.
Yup - 80 HP tune, it had a "Stinky Spike" on the ICP when he let off the throttle.
During my research on this very issue, I've learned that this is what we have to expect with a tune over about 60-65 HP. A good tuner can keep the ICP up and the IPR down with a 60-65 HP bump, but 80 HP is asking too much from stock sticks - and you get these results. Does it make 80 HP? Yep. Does it have better 0-80 time than a 60 HP tune? Nope. I have seen it over and over and over....
I know what some are saying - "Tugly's talking out the wrong orifice". Test it for yourself. If you don't have a good 60 HP tune at your disposal, just feather the throttle in your 80 HP tune to keep the IPR at about 40-45 and the ICP at 3000 while logging your speed. Compare this with the WOT times when done.
More to the point - that 80 HP tune looks as expected. While it's nice to get the kick in the pants one gets from an 80 HP tune - it has a very narrow window of this "impressive" performance. Once out of the window, the truck then performs in less-than-permagrin mode. A 0-80 WOT run is the real test of a tune - and I have seen the 60 HP tune beat the 80 HP tune at this countless times.
That's the tune, but your truck looked healthy in stock mode. I can't say all is well... only you can. I can say that with the limited data I have from afar, I see good numbers.
