Did Ford use the Dana 44 in their station wagon or sedan delivery?
A fella on Ford Barn has this year/model passenger diff. FS with a 3:54 ratio.
If compatable this may be of interest to someone here for a gear swap.
Yes, Ford used the Dana 44 in station wagons and sedan deliverys during those years. I think the rear brakes and bolt pattern are different. The ring, pinion, and carrier should swap into the F-1 axle.
