Rear-end clunk on startup. 2011 XLT 6.2 SRW
The last couple of weeks a new clunk has appeared on my F350, 6.2 CC LB FX4. If I've been parked for a while, when I drive off, within the first 30 yards or so there's a clunk. Seems worse when I've turned sharply out of a parking spot. Sounds like the rear diff or drivetrain... I have a locking rear diff. Is this engaged or disengaged while "at rest"? Could it be that its slow to unlock when I start? Thanks for any help and suggestions.
It should be disengaged when OFF, and engaged when ON. If you turned off the vehicle while it's ON, I believe it would stay ON, and still be ON at the next startup.
See if it still happens when you turn Trac & Stab control off. press once for Trac off, hold 5 seconds for Stab off.
If it wasn't there before, and now it's constant, and it won't go away, then it's prob not a normal function..
What rear gear do you have btw?
Also check your shocks. They'll rattle more than just at start up though. I had a loose rear shock on my 2011 F350 last year. Took me about five months to figure it out. Thought it was something rolling around in the back. Finally decided to check the shocks; they were loose enough to move with my hand.
Have you had a chance to visit your dealer since the clunking started? Please let me know, along with your kilometers.
Meagan
Odometer is around 180K
