Steering stabilizer question
As some of you know I just recently had new leaf springs installed with new U bolts. Well I bought a new dual steering stabilizer and the instructions say to remove 2 of the U bolt nuts on the driver side to install the mounting bracket. Will this ruin the U bolts? I know you should never reuse U bolts but these are brand new. I wish I would've known this before hand.
No, it's no problem to unscrew the nuts.
The issue is when the U bolts have been torqued down, driven for years, stretched, strained, heated and cooled, wrenched on, etc. Then if they're removed and reused, they're not in the exact same position they were before, and the stresses are put onto a different area of the ubolt.
Then they may break.
Just my personal opinion but if the ubolts are being held in their proper orientation--not moving on the hangar-I think it would probably be fine to put new nuts on. I would test the torque on them after a week to be sure they are properly tightened. Metal tends to creep over time. If you just had new springs put on recently it's probably not an issue. If they have been on, say a year, I'd replace the entire ubolt
If you want to know what actually happens to metal as it is being stressed then
Rather then get deep into an engineering rant that nobody is likely to read much less learn anything from I will just leave this link
Yield Strength - Strength ( Mechanics ) of Materials - Engineers Edge
And for good measure here is a explanation of torque to yield fasteners in laymen a terms
https://en.m.wikipedia.org/wiki/Torq...yield_fastener
And from that link.
A drawback with TTY hardware is that it normally has to be replaced when loosened.
And from that link.
After speaking with the good folks over at ATS I feel good about moving forward with my installation. The nuts will torque down on a different part of the threads than before so, there should not be any issues. They assured me that this is very common when installing the steering stabilizers.
If you were using a washer before then you have already accounted for its thickness in relation to where the nut engages the bolts treads. Did ATS recommend new nuts or just use the ones that the threads have already been torqued to yield ?
Any how, just because it is a common practice doesn't make it correct. But at least you know what to check first if you get, death wobble, wander or some other handeling quirk.
