1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Mounting rear LED lights
Old 02-02-2016, 06:19 PM
mattymax's Avatar
mattymax
mattymax is online now
I wanna put a set of rear LED lights on the rear of my truck under each bumper corner for plowing. The wiring isn't an issue. I looked under each corner and there isn't too much to mount to. Any ideas ? It's an 08 f350
I can't put them directly in the center because I have the salter mounted
Thanks
Old 02-02-2016, 06:28 PM
pirahnah3's Avatar
pirahnah3
pirahnah3 is offline
I had a set done for backup and the installer just drilled a small hole in the bumper and they are fine. Had over 30k miles and no issues with them. I know not your application but you should be fine with it.
Old 02-02-2016, 06:48 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
I put mine in my custom 6x8 bumper...For plowing or for any work truck I don't like anything hanging down anywhere cause stuff jumps out and they will get ripped off for sure. I would find a way to keep them from going under anything...How about on the sander? Higher is better.
Old 02-02-2016, 06:55 PM
mattymax's Avatar
mattymax
Yea I was thinking of on both sides of the salter pointing outward. I would like light back there also when the salters off, off season, but def not as important as when I'm plowing.
Old 02-02-2016, 07:13 PM
fishbones182's Avatar
fishbones182
fishbones182 is offline
Cut the bumper and flush mount them. Had s set of rigid lights in my f150 mounted that way looked great
Old 02-02-2016, 09:53 PM
mattymax's Avatar
mattymax
That is an option. Those Rigids are hella expensive $$$
Old 02-03-2016, 12:51 AM
im2tall33's Avatar
im2tall33
im2tall33 is offline
I had a set of leds flush mounted in my last f150's bumper and loved them. They werent rigids. i had them for over a year and had no problems with them and they were $50 for a pair on amazon.
i went a slightly different route on my 08 though. I bought two single row led light bars an mounted them under the bumper and they work great, maybe a bit overkill though, i can see about 150yards in reverse lol.
Old 02-03-2016, 05:31 AM
fishbones182
That's what I'm looking to do with the f250 is add light bars to the rear.
Old 02-03-2016, 10:27 AM
mattymax's Avatar
mattymax
Any pics ?
Old 02-03-2016, 10:39 AM
im2tall33's Avatar
im2tall33
this is the only one i have of them right now on the f250
Old 02-03-2016, 12:28 PM
SHAWZER's Avatar
SHAWZER
SHAWZER is offline
I mounted 1 on each back stack pocket , works better for me up high .
Old 02-03-2016, 12:35 PM
gasman6674's Avatar
gasman6674
gasman6674 is offline
Here is what I did, Tied them into back up circuit on 7 way. I also added Phillips led bulbs in the factory back up sockets. I just used a self tapper into the bumper support.
Old 02-03-2016, 01:08 PM
wizkid00104's Avatar
wizkid00104
wizkid00104 is offline
I mounted mine on factory holes in the hitch. These are Tuff LED Lights 27W flood lights.
Old 02-03-2016, 01:49 PM
mattymax's Avatar
mattymax
That's exactly what I'm looking for.
I would like to put them on the salter and be done with it but I would love like back there on the off season.
Thanks
Old 02-03-2016, 01:56 PM
NorEasterMA's Avatar
NorEasterMA
NorEasterMA is offline
If you have a trailer hitch, consider mounting them there. I installed a set of LED's on a customers truck by drilling two holes into the OEM trailer hitch. Once I drilled the holes I sprayed a bit of fluid film into each hole to help with corrosion and bolted them on. Looks sharp, they're tucked out of the way, and throw great light. Here's a few pictures Name:  photo434.jpg
Size:  754.0 KBName:  photo244.jpg
Quick Reply: Mounting rear LED lights
