do 1997 F250 7.3L have Inertia valves?
I have had issues with the #22 fuse blowing, till I found out thru this website about the fuel heater issue in the filter housing and have since disconnected it. and have had not other problems with the fuse blowing again. but after just a few uses of my truck since the fix, I hit a large bump in the road and my truck just died like before when I blew #22 fuse, so when I went to trouble shoot it, I found the fuse good along with all the other fuses. checked for disconnected wires related to the fuel system and found all in good working order. But now I read on this website about a fuel inertia valve. but I cannot find it. I have looked in the kick panel on the right side, under the hood. and still cannot find. so does this model have that valve? or do I have another issue I am not aware of? HELP I am broke down in my driveway.
yes the wait to start does come on for the appropriate time. and there is no smoke from the exhaust. it cranks very good.
I did tie up the heater element wire and I also wrapped it in electrical tape and zip tied to another component that has insulation around it. I checked to see if that was still in good shape and it was. besides if it did short out somewhere, it would have blown fuse #22 again and it did not blow.
to z31freakify, refresh my memory what is the CPS? I know i should know this, but I forget.
Okay, I just figured out what the CPS is, and yes it was one of the things replaced when I first had the fuse issue, before I found the fuse problem, we just assumed it was the CPS. it is a known good one. and when my cps did go out before, I had now wait to start light and no tach reading, and now I do. so I don't think it is. but for some reason I cannot communicate with my ob2 fault code reader. all I get is error, and all the fuses are good. I am getting power to the unit.
A generic code reader does not communicate with our trucks.
So you now have both WTS AND tach movement?
Check all the UVCH connectors. Also check the connector to the IDM.
It's possible, but not likely, that it's fuel-related. You should check for fuel pressure at the schrader valve on the FPR. Also check to see if the fuel bowl is filling.
No such valve on the passenger side. The fuel lines run down the driver's side. You were probably looking at something referencing a gasser; their fuel systems are completely different (it's a matter of engine fuel type, not model).
so please tell me what the HVCH is and the FPR are? I know where the schrader valve is and i wil check it tomorrow.
thanks all.
IDM is the injector driver module. Mounted on the inner fender, driver's side. It's a "dumb slave" to the PCM, receives signals from the PCM of when to fire which injector, and boosts the voltage to 120VDC to fire the injectors. Another possible IDM issue is water incursion. You can disconnect it, unbolt it from the inner fender, and give it a shake and listen for water sloshing in it.
About the inertia valve on the fuel line, some of us have replaced the mechanical fuel pump with an electric one and also installed an inertia switch on the wiring to the pump. That may be where you read about the inertia fuel line valve.
The only time my truck has failed to start was due to low oil level in the High Pressure Oil Pump (HPOP) reservoir. It's supposed to stay automatically full, but for some unknown reason decided to get empty. I filled it up with fresh oil and it's been fine ever since. The reservoir is located at the front of the engine between the top of the fan and the fuel filter. Easiest way for me to check the level and fill it was to remove the sensor on the top of it. The hole is kind of small and an equally small funnel helps. There is also a plug on top you can remove and fill through it.
Worth checking that oil level since it's a simple project and just might be your problem. Good luck.
