Rsk...... who has it
From my RSK install I learned that this is the front Bilstein shock most people install:
The Bilstein part number for the front is:
33-185552
with expanded/compressed dimensions of
25.93"/15.91"
255/70 compression/expansion valving
Was told that the dampening number is means 2,550/700 newtons of force.
I wanted shocks with more rebound (expansion) dampening and am now using these:
Front shocks, Bilstein part number: 33-230344
15.91"/25.93" compressed/extended lengths
360/80 compression/expansion valving
Lolman I feel missed.... been working alot on a road job running a d8n. ... so not a lot of free time.... and to top it off girl friend has been looking at rings....:-( and a new house on a good note I did find two boxs of ps obs parts in the garage yesterday I got like 2 years ago....lol
Bilsteins
How do you like the new shocks? Compared to the old ones???
Bilstein makes a lot of different shocks... What is the part number?
33-185552
25.93"/15.91"
33-185552
25.93"/15.91"
'Old ones' as in the factory ones or 'old ones' as in the first set of new Bilsteins?
The factory shocks had 160k miles on them. But, they were controlling front and rear leaf springs that were factory, stiff as an I-beam. So, overall the ride sucked.
The rear B codes and front U codes with the first set of Bilsteins was waterbed cushy.
In fairness I did not get the sway bars (dinked around with rear only, both, and rear) until after I got the newer stiffer shocks. Body sway is an issue as I (and the family) drive %99 on the street.
The new springs, added height and short wheelbase (of the F250) caused a kick up in the rear after the rear shocks compressed, and then extended. I'd hit a bump, and after them bump, the rear would kick up as the shock did not proved enough expansion or rebound resistance. I wanted a bigger second number and found catalog part numbers that met my needed compressed/extended dimensions. The second pair of Bilsteins stopped the kick, but are now a little too stiff on compression.
If I had all of my Bilstein money back, I could have bought custom valved shocks that had the compression of the first set, and the rebound of the second.
Not sure if I answered your question though?
33-185552
25.93"/15.91"
33-185552
25.93"/15.91"
#28
The F4-BE5-6249-H5 has 255/70 valving which is the same as my first set. Yes, with them the front moves a lot just daily driving, I can imagine with a trailer... I may go back with them though to see how they mix with the stiffer rears.
#29
Jim40216
10-03-2016 01:23 PM
