explorer keeps stalling
Sounds perhaps like it could be the classic IAC (idle air control) Valve. When it gets gummed up with carbon it tends to stick and give you problems similiar to what you describe. What you want to do is remove it from atop the intake. You should see some black carbon deposits inside the valve. Spray some carb cleaner inside it and clean it out with something like a small toothbrush. I used Q-tips, but whatever works. But, send some more info about your truck's year and engine to be certain that this is your problem and I'm sure you will get a response.
My 99 XLT 4x4 was doing the same thing. I have 160,000 miles on it and the problem just started. I pulled the IAC and cleaned it. It was pretty dirty. I then checked the unit and the system as outline in the Hanes manual. Everything checked out fine so I reinstalled it.
The whole process took about 15 - 20 min max.
So far so good.
Would probably be a good place to start.
Mark
So far so good.
Mark
Eve Bates
02-24-2015 06:42 AM
2kEB
04-15-2011 01:26 PM
