explorer keeps stalling - Ford Truck Enthusiasts Forums
Old 08-09-2003, 08:43 PM
dmichael dmichael is offline
dmichael is starting off with a positive reputation.
Angry explorer keeps stalling
It doesn't happen often, but the Explorer keeps stalling when we approach a stop sign or red light. It gets to the point that we have to put the vehicle in neutral to start to SUV and in order for us to move!
Old 08-14-2003, 12:39 AM
1999EXP_XLT 1999EXP_XLT is offline
1999EXP_XLT is starting off with a positive reputation.
Sounds perhaps like it could be the classic IAC (idle air control) Valve. When it gets gummed up with carbon it tends to stick and give you problems similiar to what you describe. What you want to do is remove it from atop the intake. You should see some black carbon deposits inside the valve. Spray some carb cleaner inside it and clean it out with something like a small toothbrush. I used Q-tips, but whatever works. But, send some more info about your truck's year and engine to be certain that this is your problem and I'm sure you will get a response.
Old 08-16-2003, 11:49 AM
flyncasafo's Avatar
flyncasafo flyncasafo is offline
flyncasafo is starting off with a positive reputation.
dmichael is probabaly right. My 2000 has been doing the same thing and I took it to the dealer today and they replaced the IAC. It fixed the problem for now. I have 47K on the explorer now. Hope this helps.
Old 09-02-2003, 10:22 PM
pn8baller pn8baller is offline
pn8baller is starting off with a positive reputation.
My 99 XLT 4x4 was doing the same thing. I have 160,000 miles on it and the problem just started. I pulled the IAC and cleaned it. It was pretty dirty. I then checked the unit and the system as outline in the Hanes manual. Everything checked out fine so I reinstalled it.
The whole process took about 15 - 20 min max.
So far so good.
Would probably be a good place to start.
Mark
06 ford explorer TaraLyne1010 Explorer, Sport Trac, Mountaineer & Aviator 3 06-28-2016 05:36 PM
95 ford explorer stalls in drive Eve Bates Explorer, Sport Trac, Mountaineer & Aviator 3 02-24-2015 06:42 AM
Exhaust sucking air treeguy58 Explorer, Sport Trac, Mountaineer & Aviator 9 12-18-2012 05:39 PM
2000 EB Stalls when put in drive but works fine in Reverse 2kEB Explorer, Sport Trac, Mountaineer & Aviator 9 04-15-2011 01:26 PM
F250 stalling out - help auctionsagain 1999 to 2016 Super Duty 9 08-01-2008 10:50 AM
Tags
2002, 2005, explorer, ford, stalling, stopped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
