96 4.9 engine swap with 94 5.8 motor
You have some added challenges since you have an OBD-II computer and associated wiring.
The problem becomes dealing with the DPFE (flow-based) EGR system and the Mis-fire detector that computer is expecting to see. Your 1994 5.8L engine has none of those. The Mis-Fire detector could probably be omitted, but the DPFE feedback system will need to be sourced.
Leadhead hit the biggest obstacle, i.e. the connectors to the cab are not always pinned the same between model years. Sometimes they change between engines.
You need EVTM diagrams for both trucks to see how you can make them work.
I did misread your first post. All the wiring and computer are from the '94 donor, correct? If so the EGR issue is moot.
No issues there if done correctly. Leave the TAB/TAD solenoids electrically connected, remove the plumbing, then plug the ports on the back of the heads.
There were various belt routing schemes used on these trucks so getting a shorter belt to work may involve some trial and error. The key is getting enough belt wrap around the alternator and water pump.
Subscribing.
This is going to be truly interesting & I wish you the best of luck.
For simplicity's sake (& we're all on the same page), You're turning a 96/4.9 OBDII into a 94/5.8 OBDI. Right?
I'd second getting the 2 relevant EVTMs.
Think I would change the 4.9 harness & computer to a 96/5.0 mass-air. Just sayin'...
I got antici and bought the motor and trans for $1000. It came with anything I needed. Which is sweet, cuz I keep coming back to the yard and the guy just tells me to take whatever I need. On top of that if I need a part pulled, they pull it. But yeah I'm going from a 96 4.9 mr5 to a 93 5.8 automatic with a 94 cpu and harness from where I've pulled a zf5.
I think I'm going to delete the smog and the cats and true dual it out to the back. God typing this out makes it sound so much more crazy. Lol
I finished my 4.9L to 5.0L swap a couple of months ago and can see a couple of issues you're going to run into from your list of parts. If you're going to an automatic then the ZF5 harness and the ECM isn't going to play nice with the auto. It may work with a C6 or old AOD, but if you're using an E4OD you need a different harness and ECM.
Having wiring diagrams of both systems is a must. It isn't going to be plug and play - I had to chop out a ton of stuff from my donor harness, map out the connections, and graft in appropriate connectors to tie it in to the harness. If I were you, I'd find an appropriate 5.8L harness and ECM from a '96 and change whatever is needed to make all the connections to the engine.
As for crazy - the deeper I got into mine the more I realized it was far more complicated than I anticipated. The engine harness took me 2 weeks working weekends and after work to get right.
