C & F Is the glass the same?
Old 02-02-2016, 06:40 PM
mytoolman's Avatar
mytoolman
mytoolman is offline
Hi all,
My artist has my 1955 C600 COE truck in his paint shop. All the glass is coming out. I dont want to put the 60 year old stuff back in. Does the pick up (F) and the CAB OVER ENGINE (C) use the SAME Glass? I cant get anyone to answer (yet). What parts book would show this answer? I dont like the "order it and send it back if its wrong" answer. HELP!!!!
Old 02-02-2016, 08:33 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,615 Likes on 1,456 Posts
The windshield should be the same. The rear window would be the same. I think the door glass would be the same but not sure.
I am sure a COE owner will chime in. In the mean time Google images of COEs and F series and visually compare them.
Old 02-03-2016, 04:55 AM
pweng1's Avatar
pweng1
pweng1 is offline
I am curious to find the answer also. I havent had a whole window in any of mine. I was told that they are same from 48-52. even though the mechanism is different.
Old 02-03-2016, 05:39 AM
GJCAT's Avatar
GJCAT
GJCAT is offline
Glass C&F
Gary, the glass is the same between C&F series. On my 56 COE I`m going to modify the doors from an F series to fit my truck. Can`t seem to find any COE doors around here. How`s the project going?
Old 02-03-2016, 10:17 AM
mytoolman's Avatar
mytoolman
Thanks Garry..it's going great dmv registered my truck! I found the frame vin....wow is that precarious. ..not very deep stamp marks on the frame. My frame is very clean this truck has lived a sheltered life previously it's very clean. Those marks were obviously never that pronounced. I'm sure dmv "classified" this C600 wrong. The dmv lady isuing the license plate only gave me ONE license plate like a semi tractor gets. "Your classification only gets one plate not two" I didn't fight it and am happy its registered now. I don't think there is a negative in what was done..if so I'm sure it can be fixed later. I have enough proof that I haven't changed anything since their inspection that would make it a different classification. I'm in the process of separation from my tool franchise affiliation. That has been stressful. I've found a slide mechanism for my 8kw diesel generator that will power all the store needs inside the box should have that assembly in 10 days then need to plumb that in. I also need to figure out how to rig up the a/c for the box. The isuzu donor truck utilized an under the hood engine driven compressor for the big condenser unit mounted on the box. I want whatever compressor is used to be spin independent of my truck's engine. I don't plan to idle this truck''s Y block engine to power the store''s electric or a/c needs. Any suggestions on what to do there? I do have the a/c compressor out of the diesel Isuzu donor some electric compressor? I'll have plenty of electricity available.
mgargiullo
15
07-31-2014 09:45 PM
wallster
01-03-2014 11:33 PM
pineconeford
04-14-2013 03:09 PM
Wayne S
08-22-2011 09:13 PM
coetruckster
01-25-2004 09:22 PM
Quick Reply: C & F Is the glass the same?
