01 f250 cruise won't power up
While holding the off switch turn the key to on. The cc indicator in the cluster should flash once indicating that it has entered diagnostics mode. If you don't get the flash you might have a blown fuse or bad switch, but there's a lot to check. The light should briefly come on in the cluster when you turn the key on to show that the bulb is good.
So, found two 2.5 amp fuses in wiring harness below master cylinder, not sure if they are the one’s suggested or not. One was bad, but changing it did not help. The master cylinder switch shows continuity and jumping the plug did not help either. The 6 prong clock spring connector shows voltage on three wires feeding the plug (black W/pink 12.4 Volts – fuse 13, Blue wire 11.4 volts – don’t know source, and Blue W/ping only 0.6 volts, three wires have continuity to ground Black, Blue W/ Red, and Gray W/ red. Light on dash never lights up, even when key is turned on, so will not enter diagnostic’s. Tried setting cruise on trip just in case light was bad, but nothing worked. Could light and rear differential switch be bad? Could it be something in the clock spring? Thanks
You will not "see fuses", they're buried in the recall harness and there were multiple version of that harness manufactured.
Go look up your VIN at Ford's recall check site and see what the status of your truck is regarding recall 05S28. If it hasn't been done, disconnect the switch on the master cylinder and inspect it for any fluid. Leave it disconnected for safety's sake regardless if you do not have the fused harness installed.
Power Strokeme
11-28-2007 06:48 PM
