Rear Suspension Problem
Okay so I have a 2003 F150 4x4. I think I might have a problem with my right rear shock because when I am driving slowly or get out of the truck, the rear end squeaks a little bit. But when I stand in the bend and jump up and down, it doesn't squeak at all. It's annoying and was wondering if there were any ways to diagnose this problem without buying new shocks? Would love some opinions and advice.
Thanks!
Thanks!
If the shock is bad, normally you will get an excessive bounce when you jump on the bumper.. Normal is for the truck to become stable quickly after you stop jumping.. Also whey you corner at high speed , if you feel the truck "floating" around the corner it can be the shocks......They are not repairable unless you see the cover or boot dragging and causing a noise, that you can remove or bend slightly..also look at the rubber mounts on the end of the shock if you think the noise is coming from them.
f-150 1996 please help me
code came up on my 1996 f-150 xl 4.9l P0155 I know there is three o2 sensors but I can't figire out where the bank 2 sensor 1 is .I know sensor one means upstream so there is now two sensors up stream .one on each manafold . Witch sensor is it the one on the manafold closer to the firewall or the one on the manafold closer to the radiator? Can anyone help me please ?
52runner
06-07-2011 11:10 AM
