86 F250 dying at idle
#61
Ctubutis, thank you again for helping out. I'm gonna trace that wire down and test it.
I was hoping by swapping harnesses, I'd fix the issue. No such luck.
The computer should be correct for the truck. It's an advance auto purchase though. I've tried swapping computers on it with no change in issues.
#63
Got to do some testing on the truck today.
Got 11.9 volts on the IDM wire at the plug going into the ICM.
Tested resistance of the IDM wire at the plug going to the computer and the ICM plug. Got 20.6K ohms.
Drove the truck about 3 miles down the road and back. The truck drove fine, but smelled like it was running extremely rich and idled a little rough.
Read codes again, and the only code it threw was 41 KOER, system pass on both KOEO and CM.
I'm a little new to testing electronics, so I'm including a picture of what I had the tester set to to read resistance to make sure I had it right.
Thanks to all!
Thanks to all!
#64
#65
Update again: Timing mark goes counterclockwise with the spout connector in place and moves as you rev the motor.
Truck is only throwing one code now: 41 KOE(always showing lean), showing system pass on KOEO and CM.
I think my timing might be off, I've heard it's possible for the timing marks to slip on the crank pulley. Is this really possible?
The reason they added the ground wire to the later model sensors was due to the bad ground path, due to gaskets, rust & corrosion. Less than $10 for a strap, or make your own (If you make your own, use solder at all crimp connections.)
Have you replace your plugs and wires?
#66
I've replaced the plugs and wires.
Been driving the truck around a little and to work and back (5 miles one way) while running injector cleaner trying to see if that helps.
Truck has died on me twice, both times was while my foot was in the clutch and the truck was down to an idle. The first time was at a stop sign, the second time I was coasting to turn into my dirt road.
The truck does not throw the code 41 if I let the truck get to full operating temperature before pulling codes. But it does smell like it's still running rich sometimes.
I think what's causing the truck to die is it flooding out when returning to idle, but I'm not sure.
I've replaced the high pressure fuel pump, fuel filter, fuel pressure regulator, and the fuel pump relay. (All done whenough the motor swap was done)
Still using original injectors, which is why I'm running cleaner through the system, and original low-pressure in-tank fuel pump.
dworth24
1978 - 1996 Big Bronco
06-24-2017 04:30 PM
coleboy11
09-08-2016 01:48 PM
f100beatertruck
08-10-2006 09:32 AM
Guitar_Stitch
09-29-2004 10:37 AM
