excursion 3rd brake light - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 01-31-2016, 03:55 PM
Demboyz1 Demboyz1 is offline
Demboyz1 is gaining momentum as a positive member of FTE.
Has anyone changed their 3rd brake light to an led? Im doing the led swap on all the exterior lighting but i cant seem to find a red 3rd brake light. Has anyone tried using the f250 3rd brake light? Is it a direct swap?
Old 01-31-2016, 05:43 PM
mecdac's Avatar
mecdac mecdac is online now
If it flies, it dies
mecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputation
Quote:
It is NOT a direct swap.
Old 01-31-2016, 05:50 PM
Thanks @mecdac
Old 01-31-2016, 06:35 PM
pirate4x4_camo's Avatar
pirate4x4_camo pirate4x4_camo is offline
pirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud of
Been awhile since I replaced mine but if I recall it is a 921 bulb, I am sure there is an endless assortment of LED replacements for 921 bulbs on line.
Old 01-31-2016, 06:39 PM
mecdac's Avatar
Old 01-31-2016, 09:38 PM
Krazee Matt's Avatar
Krazee Matt Krazee Matt is online now
Krazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputation
I have this project on the backburner in the garage. Picked up a spare third light housing for $10 off CraigsList. The plan is to use the Dremel and cut out the back wall and interior dividers, then source a 10" LED rigid case bar (as opposed to the flex strips) and mount it to the back wall. Not sure how to affix the wall to the lense, I'm leaning towards some silicone beading but I don't know if that'll hold the back wall in-line where it used to be. I have no idea if there's even a plastic welding place local that'll do a small project, and the lense seems far too brittle for that to work. Plus I don't know to what degree the heat application would cause warping or discoloration.
Main obstacle is making the LED bar plug into an existing socket, I'm not a huge fan of cutting and splicing. Not that it matters, if it goes out I'm not cutting the thing open again anyway...
In the end I forsee myself going to simple LED bulb replacements, despite them having a somewhat localized 'hot spot' where the light source would be. Which is the whole reason I wanted to stick an LED bar in there in the first place.
Old 01-31-2016, 10:24 PM
jeremiah77 jeremiah77 is offline
jeremiah77 is starting off with a positive reputation.
Look for red 194 led bulbs...that's what I used.
Old 02-01-2016, 05:39 PM
Ya i was looking for a strip of leds not really looking just to replace the bulbs
Old 02-01-2016, 05:47 PM
Well I got curious and did a search, not surprised Recon came up. They advertised their third light for the SuperDuty to fit our Excursions, which is doesn't.
However I stumbled across this antiquated thread here on FTE where someone used a Recon from a 97-03 MY F-150 and it fit, just with a small gap all the way around. Tom(WE3ZS), do you remember anything else about this other than what was in the thread?
It also appears that IPCW has some offerings, the Recon crap popped up in there as well... http://www.carid.com/2001-ford-excur...-brake-lights/
Old 02-01-2016, 06:59 PM
WE3ZS's Avatar
WE3ZS WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
I have a third brake light assembly from an F-150 and in my opinion the fit is much too mismatched for use on an EX. I don't have a picture of it mocked up on my rig but it had too much of a gap everywhere for my eye. It's a shame too because I really wanted it to work as it's the version with the clear outer spots and red center, I wanted to load the center up with a red strip LED bar/cluster and white LEDs in the clear section to add to the reverse lighting.
Old 02-01-2016, 07:34 PM
Matt M, PA's Avatar
Matt M, PA Matt M, PA is offline
Matt M, PA has a very good reputation on FTE.Matt M, PA has a very good reputation on FTE.Matt M, PA has a very good reputation on FTE.Matt M, PA has a very good reputation on FTE.
When my Ex was new, I wanted to switch with an F150 light because it not only had the brake light....but also cargo area lights. I know some say they fit...but I compared them and didn't like the gaps, etc....
Old 02-01-2016, 07:44 PM
Vince79vette's Avatar
Vince79vette Vince79vette is offline
Vince79vette is starting off with a positive reputation.
Does they 3rd light come apart easy? I wouldnt be hard to put a led strip or 2 in it
Old 02-01-2016, 07:59 PM
Quote:
Nope, its a molded monstrosity. Post about it a few posts up.
Old 02-01-2016, 08:05 PM
mecdac's Avatar
Exclamation
Quote:
Originally Posted by Krazee Matt View Post
Well I got curious and did a search...
...It also appears that IPCW has some offerings, the Recon crap popped up in there as well... 2001 Ford Excursion Custom & Factory 3rd Brake Lights ? CARiD.com
They look hideous.
Old 02-02-2016, 12:53 AM
Peace2Peep's Avatar
Peace2Peep Peace2Peep is offline
Peace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to beholdPeace2Peep is a splendid one to behold
I actually contacted Recon directly, they do NOT have a replacement cover for the Excursion third brake light...BUMMER, especially since it would be such an incomplete look to do their brake light covers for the others and not be able to change this.
New Super Duty high trims: all LED except license plate lights? troverman 2017 Super Duty 7 05-18-2016 12:39 AM
3rd brake light possibilities tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 12-22-2015 02:56 PM
Gummy 3rd Brake Light Sockets FordTruckChuck 1997 - 2003 F150 0 03-31-2015 02:57 AM
Need a CHMSL (3rd brake light) F239141 1997 - 2003 F150 1 06-12-2014 09:54 PM
3rd Brake Light Cover? XplorerJanx Explorer, Sport Trac, Mountaineer & Aviator 4 10-21-2002 07:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
