Truck with a thousand rattles!
Old 01-31-2016, 01:48 PM
J1MMY's Avatar
J1MMY
J1MMY is offline
Evening all.
I have owned a 97 4.2 2WD auto single cab for a few weeks and while it's a great motorway cruiser (75mph is silent compared with my old '83) it certainly doesn't seem to be as well-built as its distant predecessor!
So far I have sorted most of the in-cab rattles; dash panels, door cards and (semi-successfully) the seat belt/pillar covers.
I have been battling a number of under-body rattles. What appeared to be a heat shield rattle turned out to be an I.d. tag in between one of the cats and a heat shield.
Two of the rattles have got me stumped. The first is made by feathering the throttle just off idle and sounds like a heat shield. The second appears and persists between 40 and 50 mph, whether accelerating, decelerating or maintaining a speed anywhere between 40 and 50. I have driven through these speeds in different gears and it happens regardless. I have been underneath with a tapping stick and the heat shields are not rattling when tapped, the cats don't seem to be broken up (I've had a stethoscope on the exhaust, listened through the bell housing, trans body and tail housing) and the only thing that seems to rattle when tapped is the trans crossmember - but It is tight and not visibly cracked or damaged.
The other issue is Tickover. It's a little lumpy - seems to momentarily 'miss' when sat at a junction holding the truck stationary. When sat in park, idle is steady. The truck pulls with no hesitation.
Any help appreciated - as I spend most of my time on long journeys either at 40-50 it's starting to ruin the fun of the ownership!
Old 02-01-2016, 07:13 PM
Todd Rasmussen's Avatar
Todd Rasmussen
Todd Rasmussen is offline
rattles
I had that truck too, 1997 f150, 4.6 v8, 4x4, picked up a 2002 250 superdutey ,4x4 V10,,wife took over 150, and I had to clean all my stuff out,, spark plugs, tools, ammo, in door pockets, binos under seat,,when I got done, couldn't believe it was so quiet,,, just a little humor , but true,,good luck to ya, hope some one chimes in with some real info,,
Old 02-01-2016, 08:21 PM
mudram99's Avatar
mudram99
mudram99 is offline
That's why we have radios and loud pipes, to mask the sound of all the junk we have rolling around in there!
Old 02-03-2016, 08:20 AM
J1MMY's Avatar
J1MMY
J1MMY is offline
Sounds like my company vehicle - car parts in the door pockets, empty red bull cans in the coffee cup holders, crap everywhere!
TheProfessorofTOOL
1997 - 2003 F150
12-19-2013 09:15 PM
tmoney67
2004 - 2008 F150
03-10-2006 06:34 AM
only1kirk
05-26-2005 10:22 AM
true4.2
3.8 & 4.2L V6
22
03-01-2005 11:12 PM
jmpc
1983 - 2012 Ranger & B-Series
10-17-2003 02:20 AM
Quick Reply: Truck with a thousand rattles!
