Consoles
This was for my Bumpside but it also applies to the Dents since they are generally sisters under the skin....
Here are a couple of choices using common Ford donors.... on the left is a 95-ish console out of an F150 SuperCab and an early 90s Bronco - both were equipped with buckets. Note the difference in height and the more square shape of the Bronco console.
The plan included '70 Mach 1 buckets with TMI Sport foams and upholstery and the Bronco console.... but upon installation of the seats I discovered the bolsters were really wide so I needed to use the 95 console because it tapers narrower in the front. Due to the odd shape of the bottoms shown above, I fabricated a lightweight bracket so it would sit level at a comfortable height.
Painted, assembled, and installed...
These are 40/20/40 seats from a 2010 F-150. The original seat brackets were removed and the tracks mounted to 1" box tubing. The console (and internal cubby) was shortened by taking 1.5" off the bottom and fabricating brackets that mount directly to the floor. Cupholder wasn't modified and the cool thing is, the console flips up and serves as a center seat as well. I've seen similar consoles on ebay.
BTW, HIO, I really like your exhaust solution through the trans. mount crossmember. That's the kind of innovative thinking I need to keep in mind!
10.4... I had plans a coupla weeks ago for the FF yard but the rains doused that idea. Hmmm.....
No it's an acc vinyl floor. I was thinking of bed lining the floor but I wanted the insulation. My daily drive is 36 miles one way. I wanted to hear myself think when I got there.
