92 F150 Neutral Safety Switch
I am starting to have a real problem with the neutral safety switch on my 92 F150. I have 105,000 miles on the truck. I have posted a couple of other messages on this problem but I cannot seem to get it narrowed down. Can someone tell me where the switch is located. Do they go bad and are they hard to replace? The Ford dude wants to sell me a whole new clutch. I have looked under the dash and on the firewall but cannot seem to locate any likely suspects. Any help will be greatly appreciated.
Charlie
Charlie
the saety switch shoube attached between the clutch master cylinder and where the the linkage connects to the pedal. the reason the pedal pushes hard is the pressure plate is worn out. i have seen several cases of this, anda new clutch and pressure plate is needed. dont forget to get the flywheel resurfaced. by the way- my name is chuck moore
Charlie Tee
1983 - 2012 Ranger & B-Series
09-14-2015 06:36 PM
teachingscience
06-16-2015 06:25 PM
1981fordstepside
15
05-14-2014 05:21 AM
MTrumpy
07-19-2007 08:08 PM
