intermittent nightmare wont satart please help.
That thread also has a lot of good info for testing the coil
after replace the coil and the control module and throttle switch was no change I took the sparkplug out and clean them it started seams that's running rich I try to start again and it didn't start so I switch to the front tank (empty tank) and it started so became clear that the truck is flooding on start and getting too much gas, I run it for a wile and get the codes from the dash and I got 116 116 154 254 354 254 3 ECT out of self test range 0.3 to 3.7 volts., could not find 154 254 354code on the book,
any help would be appreciated
this what i got from this link Ford ? OBD Trouble Codes
<table align="center" border="1" width="87%"><tbody><tr><td>117
</td> <td>(O,M)
</td> <td>118
</td> <td>(O,M)
</td> <td>
</td> <td>
</td> <td>
</td> </tr> <tr> <td>
</td> <td>
</td> <td>
</td></tr></tbody></table>
</td> <td>
</td> <td>
ECT sensor is/was low or grounded – ECT
</td> </tr> <tr> <td> </td> <td>
</td> <td>
ECT sensor is/was high or open – ECT
</td></tr></tbody></table><table align="center" border="1" height="52" width="907"><tbody><tr><td></td> <td>
</td> <td>
</td> <td>
</td> <td>
I am still getting code 117 I don't think it has a polarity and bought wires was white on the new, I not sure if I connected it backwards but the truck runs great it take a few turns to starts it also giving a code on the fuel pump but it maybe because the front tank don't work. when it get warmer I will try to figure it out
#30
Problems are when the voltage is not reported back to the ECU correctly...maybe it doesn't change or the voltage jumps. The ECU uses the TPS voltage to control the part throttle flag and go into dashpot and part throttle spark control. When it can't calculate this correctly the motor can run bad.
tubby12729
09-04-2012 09:41 PM
smbutton91
12-06-2010 11:03 AM
