Transmission
Transmission
I have a 1994 Ford F150 5.0, 4R70w transmission. The other day it started giving me problems moving forward. From a stop I would have to give it a lot of gas and then it would jump forward. No problem moving after that. I could go in reverse with out a problem. I decided to change the transmission filter. Did not find any metal once I drained to fluid. I put in a new filter and topped the transmission off in neutral. Could not get the truck to move after that. Will not go forward or reverse.
06 F150 4x4 no forward
Transmission rebuilt 20k ago. All of the sudden tonight I go to Wendy's and have no forward . ..little movement, but full reverse . No burnt smell or anything . It was in an accident in April, and the FORD dealer replaced the cooler. When I was driving it out of state for work I discovered the dealership didn't install the seal and line properly and had to continuously full the granny all the way from Florida to Virginia where the insurance had the line replaced . Drove with no problem from Virginia to Louisiana been here for a month and a half. I did notice that the dipstick indicates the fluid level is double what the hash marks are telling me that the second shop out too much fluid in. I am changing the fluid, filter and gasket in the morning in a likely fruitless attempt to fix my transmission without spending another $2500. Any thoughts on what could be the cause or anything to look for ?
Ok
I decided to post here because I saw some professional answers, and was expecting an informative response
The issue is the '06 trucks are very, very different than the '96 trucks. The people that know about the '06 trucks don't really visit this section of the forum, and vice-versa. The people in the '06 section are far more knowledgeable about your truck.
Mrrolling's post was definitely unnecessarily rude, though.
Understood
I understand , and thanks. the thing is that it's the same transmission . No big deal .
Not really the same. The later 4R70Ws have a lot of internal electronic and hydraulic differences, as well as a completely different control system compared to that makes diagnosing them different from the earlier trucks.
scott351wind
06-16-2018 07:51 PM
Travis Martin
1978 - 1996 Big Bronco
05-24-2012 01:29 PM
1968F100ShortBed
07-20-2005 09:51 AM
