ZF-5 Clutch: Trouble in Paradise
One thing with the clutch disc that could cause your symptoms. One of those little coil springs in the clutch disc may have come out of place and is binding in there between the flywheel or pressure plate and won't let the transmission input shaft stop when you push the clutch pedal down. I have experienced this and also read about it on these forums.
justa FYI. all the symptoms you listed have Nothing to do with a worn clutch
Slave and master cylinders replaced 5 months ago
Awful grinding noise when trying to shift into reverse(worn bearings, syncros or not enough disengagement)
Occasional grinding when shifting from 1st-2nd(bad syncros)
Hard to shift into 1st from a stop(not enough disengagement)
"Clunking" into gear while moving
From what I understand, there is no syncro for the reverse gear in this transmission, so not fully disengaging seems to be the most likely explanation.
The PO told me that he always launched in second gear, so it wouldn't surprise me if the syncro was on its way out. Unfortunately, a transmission rebuild is simply out of the question for me right now, so that will have to be addressed at a later date.
Received 3,107 Likes
on
Where can I find the actual process to replace it? I found the instructions for replacing the pedal box bushings, but that's not what I'm after. I'm young and able-bodied, my problem lies in the fact that I'm attending work training and away from home. However, I have a class full of heavy equipment students who're ready and willing to do the work on it for me.
on
i found this: https://www.ford-trucks.com/forums/7...ml#post5794495
unfortunately, i never had to replace the bushing so i can't help you on that part.
It's really simple on these trucks.
Pop the master cylinder pushrod off with a big screwdriver or small pry bar.
Put the new four fingered bushing in the'eye' of the pushrod, and click it into place.
I used a pistol casing with a snap ring in the extractor groove for a while, and then made an oilite bronze bushing with a washer retained by a hairpin clip.
You can get the plastic clip from the autoparts store.
it's found in a Dorman assortment of windshield linkage retainers.
Oh wow, that's even easier than I thought. I figured I'd at least have to unbolt the MC and pull it off the firewall a ways in order to remove it from the pedal arm.
Already ordered a Ford OEM bushing. Out here in the boonies nothing's cheap, and NAPA would have to ship one in from the city. Just as easy to order online.
You can see the four fingered clips here.
It's an add-on item, so you only get free two day shipping if you combine it with something else
http://www.amazon.com/Dorman-49447-W.../dp/B000IWFPIW
on
#28
That's what I'm saying!
Although, this clutch is past the 160k mark, so chances are it'll need replacement sooner or later. And I really should pull the transmission at some point and have it serviced, bearings and syncros checked...
charlessocccer
34
12-15-2010 03:17 PM
1990F2504604x4
22
10-07-2005 09:54 PM
