Safe to drive without lock hubs?
So after eight years my Warn premium hubs have taken a crap and developed major play internally. After speaking to Warn warrenty department and sending videos they will replace them according to the lifetime limited warranty. Problem is they sill not send out new ones until they receive the old ones, so I was told from time i remove mine and send them back and get the new ones it will be two weeks maybe a few days more, there is no snow in the extended forcast and im wondering what damage could occur with me funning the truck everday to work etc with the stub shafts just hanging there?
on
HUBS
NO, You can't drive around with nothing in that hole. You will get dirt, sand, salt, and a lot of other crap in there.
SOLUTION: Ask them if you can pay for the new ones with one of your credit cards, and then when you receive them, you swap them out. You then send them your old ones, and they credit your credit card account. That's the way everyone else does it.
RON
Im in south jersey, turn around is me shipping them tomorrow after work so around 4pm Monday, then x amount of days to get to Warn. Then they must go over the hubs before they send me new ones or tell me i did something to wear them out. In either case a few more days and then shipping to get me new ones or worse case my old worn out ones back. So two weeks easy is what im looking at
FWIW, I exploded a set of Milemarker hubs on another truck, and Milemarker sent me the replacement set, just on my promise to return the broken ones as soon as I got them (which I did). Warn undoubtedly makes a better product, but I was certainly impressed with Milemarker's customer service.
Looking at this; https://www.warn.com/corporate/assets/pdf/hubwarr.pdf. I would assume they are implying that you somehow misused the hubs. Probably a CYA thing for the CS agent you talked to. Try calling them and asking for a CS Manager. If you are still riding on the mods in your Sig, I wouldn't think they should have an issue. I would be more than willing to hit up the Clackamas center to help you out. PM me if you need any help.
I spoke to John who is i suppose the boss in customer service, i sent him the video and first thing he said was they look bone dry? I said its cuz i removed them and parts washed them so u could see/hear the amount of slop they have. He then proceeded to explain they will not warranty the hubs till they look over the ones i send them THEN they will either replace under warranty or tell me im ducked and have to buy new ones
Nojoke im calling around tomorrow at salvage yards and i know a guy at the local ford dealer and see if he has broken hubs laying around. I also emailed John at Warn tonight and asked about me buying a new set sending mine back and then getting reimbursement when the warranty the old worn out hubs
I had MM hubs first and they did nothing but jiggle on the hub and when i would regrease them once a year the internals were getting rusty some how? So after two years i had enough sold them and installed the Warns. Ive had four strictly off road mud trucks since i git my liciense and all had warn premiums or I installed a set. Now i BEAT THE HECK out of my play trucks! Im not gently, i hit holes wide open, i rip them through atv paths, over hills that high center the rigs and only speed gets the trucks to slid over them. I even weld the front diffs so i have a cheap spool and not once have i had a warn hub break. BUT on my daily driver the Warns just wore out...go figure
