P0261 code
P0261 code
Hi all. the last couple days the truck has been a hard start in the morning. about 28 deg F. I thought the glow plugs were getting weak or a couple of them were out.
Hooked up my AE and pulled codes, one of them was P0261 # 1 inj.
Truck is fully warmed up and is running fine.
Did a koer glow plug test and it came back ok.
power balance looks good now. Probly looked different when I finally got it started this morning. Took 3 cranks to get her goin and it sounded like **** till it got a bit warmer.
Any thoughts??
Any thoughts??
ok just to note I had the block heater plugged in all night as the temp is 26 deg f
I disconnected the glow plug wire from batt
koeo: ficm 47.5, batt volt 12.5
cranked over batt volt 11.57, truck started right away, the ficm might have gon down a volt during cranking??
with engine running ficm 46 to 47.5
One more thing is I never got the p0261 code thismorning, yesterday when I got the code the truck was cold, not plugged in.
Good Luck
Louie
Hi All. Ok id did a re test thismorning with the engine cold, Not plugged in temp is 30 deg f
KOEO ficm 47 v, batt 12.5V
Cranked engine and started FICM dropped to 40v ( or maybe lower since my AE will only read no lower then 40)
Let it idle for 5 min FICM went between 40v and 44v ant the last few seconds before I shut it down it reached 46v
I guess I need a new FICM
Any thoughts Please??
Well the FICM needs love!
How is your charging system health? Pull the Alt and batteries and head to your local box store and have all 3 tested! You might be surprised that you find issues there! 99% of the time the FICM dies because of the charging system.
#1 injector is easy peasey to do! My first injector was #5! That was a gem!
Oil change interval is a bit long! These things like fresh oil around 5k. 5w-40 is a nice addition to the engine. Run a round of Hot Shot diesel treatment with an oil change. It will get all the crude out of your engine.
mrwalleyeman
03-16-2019 06:02 PM
