2004 5.4 Vin 5 / vin L swap
VIN code '5' is a 5.4L 3-valve engine. VIN code 'L' is a 5.4L 2-valve engine. If the question is whether or not the bottom engine of the two engines are identical, it MAY be depending on what year and model of vehicle the intended donor engine is, versus the intended vehicle to be swapped into. If you can obtain the full 17 digit VINs of both vehicles I will be able to tell you for sure.
This is untrue. Oil filter location is dependent upon the oil filter adapter bolted to the engine. If the donor engine happened to have the oil filter located rearward of the driver side engine mount as described (such as on E-Series applications), changing its location is only a matter of bolting on the appropriate filter adapter to suit the application intended.
whatever. you tell me when the oil filter is all the way back on the engine, and then the other engine has the oil filter on the left front. I worked on the one truck, and I own the other one. and both trucks have the 2 valve 5.4s. I don't believe you block off one and move the filter.....to the front. and this was 2 different trucks. not a van.
3v top end with 2v bottom
VIN 1FTVX14564NA54098
blk dog
12-13-2010 10:12 AM
spannerwrench
10-08-2004 06:07 PM
