Modular V10 (6.8l)
Burnt Valve
Old 01-28-2016, 09:06 PM
FordKld's Avatar
FordKld
FordKld is offline
Burnt Valve
Hi all,
Had a misfire on one of our trucks that has the V10 the other night, showed 3 bad COP's. Replaced those and still have misfire. Local shop says burnt valve on cylinder 7.
I don't have much experience with the 6.8L as this is the first I've owned. Truck has 195k on it and is an 2001.
I've heard these engines can last forever so to speak with proper maintenance.. is it worth putting money into it to fix the valve? Local shop did not quote it yet but I assume this can't be more than 800-1200$ to pull the head and repair?
Thanks for any insight.
Old 01-28-2016, 11:23 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Were the spark plugs replaced or just the 3 coils?
Were the coil boots replaced or just the coils?
If it was my truck I would do some simple and free investigation into the cheap parts that are easiest to get to, rather than start peeling off thousand dollar bills to pay someone because he told me to.
Old 01-28-2016, 11:52 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
Welcome to FTE!
Burned valves aren't really a common engine problem anymore especially in the V10 (I can't honestly say I've ever seen or read of one), did they say how they diagnosed the problem? A compression test is the only way to correctly diagnose a valve problem and it WAY more common for a improperly diagnosed ignition problem to be the real issue.
Old 01-29-2016, 01:33 AM
AllAboutDaZ's Avatar
AllAboutDaZ
AllAboutDaZ is offline
could be a fouled spark plug due to bad coil
Old 01-29-2016, 06:53 AM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
I'm with Twigs. Only way to tell is a compression test. After you get the results, you can determine if repairing the head is worthwhile. The V10 can go 300k miles and above with darn near trouble free service.
Old 02-02-2016, 07:06 AM
FordKld's Avatar
FordKld
FordKld is offline
Hey guys,
Just an update -- got the truck back before they did any work on it since I was skeptical. Found that the o-rings for an injector weren't seated right and was causing what felt like a misfire along with the original COP. Fixed that and runs like new with 197k on it.
thanks for the help!
Old 02-14-2016, 10:48 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Originally Posted by FordKld
Hey guys,
That's a strange solution... So was it leaking fuel?
Old 02-15-2016, 12:05 AM
dkf's Avatar
dkf
dkf is offline
Probably sucking air at the injector with the bad seal causing a lean hole.
polarvend
1999 to 2016 Super Duty
12-28-2018 10:28 AM
mdgaf
Bronco II
04-16-2013 09:01 PM
dzdiggin'dude
Modular V10 (6.8l)
03-10-2009 02:17 PM
H20ENG
1983 - 2012 Ranger & B-Series
25
01-30-2007 11:34 AM
swhite005
1997 - 2003 F150
12-19-2005 07:42 AM
Quick Reply: Burnt Valve
