hi im new at this forum , I just finish up restoring a 1949 f1 6 cyl but I have a horrible shaking while clutch is engaiging n 1st gear or reverse, the rest of the time everything works find. Any ideas or help what would cause this.
thanks pj97
Probably a warped flywheel. You could get it machined.
I'm guessing it shudders just as bad if you try to take off in second, or any other gear for that matter. Most likely you only noticed it in first and reverse as you are getting the weight of the truck moving from a standstill in those gears.
the other posters are all more experienced than me, but one thing to check. i had a horrible chatter that was mostly cured when i replaced the tranny mount that had split into two pieces (top from the bottom). new clutch/pp, after some intentional clutch slipping it is almost gone entirely.
