1950 Ford F1 inner fender to frame connector - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Log In
Old 01-28-2016, 08:04 PM
3twinridges's Avatar
3twinridges 3twinridges is offline
3twinridges is gaining momentum as a positive member of FTE.
I am replacing my inner fender to frame connectors on both sides (I am missing the drivers side). I assume they are the same. Can anyone take a picture of theirs so that I can determine what washer combination should be used? It also looks like on the drivers side the battery tray hooks into it also? Is there a washer in between it and the inner fender? Here is what I think is the proper fastener, is that right?
Click the image to open in full size.
JB
Old 01-28-2016, 10:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant future
Are you talking about the dogleg at the lower bottom?
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree, MSD, Rochester 2G, Red's Headers
"Never attribute to malice that which is adequately explained by stupidity" -- Hanlon's Razor
Old 01-28-2016, 10:25 PM
Yes, that bolt and the bolt on the opposite side (drivers side).
Old 01-28-2016, 10:27 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a name known to allFortyNiner is a name known to allFortyNiner is a name known to allFortyNiner is a name known to allFortyNiner is a name known to allFortyNiner is a name known to all
The battery tray is on the driver's side for the I6 only. It is on the passenger side for the V8.
__________________
19 and 49 F1 jes' like Henry II built
1946 Tudor Deluxe - ran when parked
DW
Old 01-28-2016, 10:41 PM
Yes, I have the 226.
Old 01-28-2016, 10:45 PM
ALBUQ F-1's Avatar
postin' fool
You might want to consider not attaching the dogleg. They were eliminated in '52 because they always tear, just like the one in my picture. Instead you just use the two bolts along the flange
__________________
Ross
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
