To Cruise Control or not. That is the question
I have a '15 F20 6.7 and am getting ready to tow a 7Klb TT. I have read on the on board towing info and in the owners manual that we are not suppose to use CC when towing. However, I have read a few posts that say they are using CC. I hate the idea of having to keep the foot on the gas for a long distance if I don't have to. Opinions?
That seems ridiculous to me to not use CC. I have a 2000 F250 7.3 diesel that tows a 10K lbs travel trailer with CC on just fine. I towed it 7500 miles from GA to Seattle and back this past summer and used CC as much as possible. I could not imagine going across SD and Montana without CC.
You will be just fine with a new 6.7 and that weight. The truck won't even know it is back there. Set the CC and enjoy the ride my friend.
Most of my towing has been through northern Arizona, New Mexico, Colorado, Nevada, and Texas. Lots of hills. Fifth and sixth gear are both overdrives. So except for flat country with a tail wind, I keep it out of sixth gear, and use the manual mode to down shift to Fourth gear at the base of a hill instead of waiting for the truck to downshift to third or second half way up the hill.
Cruise control almost always but do kick it off when I pull our 12K 5er in hilly areas as I want to be the judge of when the transmission shifts plus want to limit rpm to something reasonable - I will let the speed drop as necessary. I seldom use Tow/Haul and instead rely on the manual shift feature which I found, doesn't have to have the lever in the 'M' position to work. As a note, I wish that manual function, 'M', was on the steering wheel instead of the shift lever where I have to kinda grope for it rather then have it in plain sight and under a thumb.
Follow-up - just towed trailer from Tampa to Ft Lauderdale. Dash info for towing said we don't need to use T/H mode on flat land. That route doesn't get much flatter, so didn't use T/H but did use Cruise Control. I initially locked out 5th for about half way then opened 6th the rest of the way. Kept an eye on trans and oil temp. Oil - 200-210 and trans - 195-205.
