battery indicator eye
Old 01-28-2016, 07:48 AM
Gary O's Avatar
Gary O
Gary O is online now
I have a 2011 6.7 with 16000 miles and it just turned 5 years old.Yesterday had hood up and notice driver side battery eye indicator was red, other battery was showing green, truck turned over and started fine. 15 degrees out this morning, truck started fine.Truck hasn't been ran for a couple weeks.What does the red indicate,battery needs charged or time for new batteries?
Old 01-28-2016, 08:23 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
I was always under the impression that if eye was red, it needed water added to the battery cells
Old 01-29-2016, 11:00 AM
69cj's Avatar
69cj
69cj is offline
http://www.autoshop101.com/forms/elec03.pdf
Check this URL. It will explain the whole process.
Old 01-29-2016, 11:28 AM
Gary O's Avatar
Gary O
battery indictor eye
Battery was bad, just got done installing 2 new BXT-65- 850 motorcraft.Got 5 years out of originals. Thanks for the info
Old 01-29-2016, 02:29 PM
doczenith1's Avatar
doczenith1
doczenith1 is offline
I had corrosion on my passenger side battery. Noticed that the eye was black. Took the battery out to clean the terminals and such and why it was out had the autozone run a check on it. Came back good so I reinstalled. No issues with cranking. I'm going to try and get another few years out of them. Living in a northern climate ought to help them last longer as heat is your battery's biggest enemy.
Old 01-29-2016, 07:29 PM
porthole's Avatar
porthole
porthole is offline
Only checking one cell with that indicator
Old 01-29-2016, 09:41 PM
JohnD333's Avatar
JohnD333
JohnD333 is offline
Yes, that eye is only to one cell. That is the most likely cell to need attention, but not always. If you waited this long to look at the rest, it is probably too late...
Depending upon where you live and how much you mind walking, I suggest 5 years and toss them, just like tires. Just not worth the risk.
Jack Priest
2017+ Super Duty
01-17-2019 10:04 PM
plumm30
2009 - 2014 F150
44
02-12-2016 01:54 PM
zer01
02-25-2015 04:54 AM
szpieleusa
1999 to 2016 Super Duty
02-02-2012 10:39 AM
aurgathor
Electrical Systems/Wiring
01-29-2005 12:50 PM
Quick Reply: battery indicator eye
