57 F100 stock rear end interchange.
The ford 9" rear end has been used in cars and trucks for years and years. Something like 1957 - 1986, maybe longer. They are quite available and still made today by aftermarket companies. Some have 31 spline and some 28 spline on the ends of the axles. The 57-60 rear ends have 28. The 9 inches in referring to the diameter of the ring gear that the pinion gear drives. The ratio is the number of teeth on the ring gear divided by the number of teeth on the pinion.
Hope this helps.
When I changed mine, I only changed the differential or "third member". No need to change the housing. Pull the axles, unbolt the differential, change the flange (or yoke) on the differential, bolt the new differential on and replace the axles. I also suggest replacing all the seals (2 axle and 1 pinion). fill with oil and you are in business.
cyber_06_wolf
10-18-2006 10:49 AM
