Rust Fixes
I plan on doing all the cab bushings anyways so will see just how extensive the rust is on the supports once I get it in the air and off the frame but I recall the supports being relatively clean (minor surface rust no rot)...its just in between sheet metal seams that are starting to go really
I may not have to depending on how far over the rust is, I wouldn't know that till either I cut our the floor board riser inside the cab or get the cab itself totally off the frame but will probably just save that area for last and fix it the same time I lift the cab off the frame to replace the cab bushings. There's no sense of replacing a cab mount if it only has a bit of surface rust on it, just need to treat the rust right so it doesn't come back but again I have no idea the severity of the rust on the cab support there as it's been awhile since I've looked. Been busy with stuff I can do in the garage like color changing the door panels and other interior trim pieces.
Do you see the rust INSIDE the cab mount in the pic? that is what the floor looks like under the cab mount if not worse
[QUOTE=0500757Arf;15989117]
[QUOTE=Diesel_Brad;16008981]Do you see the rust INSIDE the cab mount in the pic? that is what the floor looks like under the cab mount if not worse
Yeah I see it there but I also see blue paint right near it which leads me to believe it may be salvageable which I won't know till I really look into it, I was more concerned about the hole in this picture as it's on a seam where vertical metal meets horizontal if that makes sense.
ek9beezler
01-10-2016 11:36 AM
Nothing Special
10-28-2015 05:38 PM
powerstroker100
05-01-2015 06:01 PM
77_150_460
05-25-2009 07:47 AM
61 uni
12-29-2007 08:55 AM
