1995 Powerstroke throttle response
Old 01-28-2016, 06:24 PM
Seanosu's Avatar
Seanosu
Seanosu is offline
I was hoping that would solve the problem on a side not it did smooth out the idle.
Old 02-04-2016, 10:15 AM
Seanosu's Avatar
Seanosu
Seanosu is offline
I think I figured out what's going on. I was sitting in a drive through last night and I heard the EBPV close so I raised the rpm to 1500 and the valve opened immediately but while holding that rpm the valve closed and my eps dropped so this morning I unplugged the EBPV connector and the truck runs a lot better, more power down low before boost kicks in. Not as sluggish. I can now put my foot in it and rpm faster.
Old 02-04-2016, 11:01 AM
Seanosu's Avatar
Seanosu
Seanosu is offline
RPM not eps
Old 02-04-2016, 11:06 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Good deal! You learned something and that is good. Keep it up. Lots of good knowledgable people on this forum.
Old 02-04-2016, 11:13 AM
Seanosu's Avatar
Seanosu
Seanosu is offline
This forum is great, everyone is helpful.
Old 02-04-2016, 11:21 AM
madpogue's Avatar
madpogue
madpogue is offline
Hmm, you mentioned low EOT in another thread. That would also make the EBPV close more. You might want to look further into that. Maybe your engine isn't getting as hot as it should. Or maybe it is, but the EOT sensor isn't responding properly.
Old 02-04-2016, 11:25 AM
Seanosu's Avatar
Seanosu
Seanosu is offline
Coolant temp gauge never gets above the "N" on "Normal" . Outside temp 55 degrees. I'm wondering if the thermostat is stuck open or it has been removed. Il have to do more investigating. This is my first Powerstroke, I'm doing as much research on this engine as possible. I'm new to Powerstroke's but not diesels.
Old 02-04-2016, 11:55 AM
madpogue's Avatar
madpogue
madpogue is offline
How's the heat in the cab?
Old 02-04-2016, 11:57 AM
Seanosu's Avatar
Seanosu
Seanosu is offline
Warm to hot.
Old 02-04-2016, 12:16 PM
madpogue's Avatar
madpogue
madpogue is offline
The dash gauge doesn't mean much; they're really imprecise. If you have a way of monitoring EOT, take it for a good long drive and monitor it. It should get up to / toward 200F.
Old 02-04-2016, 12:22 PM
Seanosu's Avatar
Seanosu
Seanosu is offline
Ok I'll hook up AE and take it for a cruise. Do you have AE ?
Old 02-04-2016, 12:34 PM
madpogue's Avatar
madpogue
madpogue is offline
Yes, I do, but an old version.
  #28
Old 02-04-2016, 01:51 PM
Seanosu's Avatar
Seanosu
Seanosu is offline
45 min trip all highway 65-75 mph. Outside temp 48. Oil temp 176-180. 180 being the highest temp I saw. On another note. I did a cylinder contribution test and it passed. What does that mean ?
  #29
Old 02-08-2016, 09:15 PM
madpogue's Avatar
madpogue
madpogue is offline
EOT seems low. At those speeds, I'd expect 190-200F EOT. Either the sensor is inaccurate, or the thermostat isn't closing; those are the two most likely explanations anyway.
  #30
Old 02-09-2016, 02:39 PM
Seanosu's Avatar
Seanosu
Seanosu is offline
Update. Still sluggish. Maybe I'm not used to the low horse power. I still think it should pull harder before the boost kicks in. I'll check the EOT sensor and thermostat.
Quick Reply: 1995 Powerstroke throttle response
