Cold-sometimes-crank/no start
Like usual, i have a problem that no one else has and it sounds like its something electrical/sensor/PCM related.
Every few mornings, ill go out to my truck and go to fire it up...and it'll just crank away. After i give up on cranking and shut the key off, go to try again, it fires up instantly, like nothing is wrong. Sometimes in the morning itll just have an extended crank but eventually start. Regardless...it always starts. Sometimes it cranks really strong the entire time, sometimes the crank gets weaker the longer you crank...i don't think its HPO related, but i definitely could be wrong.
Ficm voltage looks good KOEO, cranking and running. I had my batteries tested at ford a few weeks ago and they "said" they were good (motorcraft 850ccas). Alternator is strong. When cranking, ive seen the voltage drop anywhere from 10.2 to 9.4v. I never know when this is going to happen and i can't hook up AE every morning and sit and wait, but based on my scangauge, i see ICP shoot up to over 1500 as soon as it fires.
Only code ive gotten is P0148, which is fuel delivery error/engine speed higher than expected. I've gone ahead and replaced my camshaft position sensor with a ford sensor a few days ago...it hasn't done a no-start yet, but it did do an extended crank. I think my next stop is PCM replacement, but figured id get some ideas from you guys before that hassle. Thanks!
Miles,
I saw 9.9v recently on a set of 850CCA 1.5 year old batteries... they are now AGM batteries. It occasionally did the same thing...RRRRRRRRR>>RRR>R and I thought the same thing, is it going to start, key off, re-try and a quick start. Hasn't happened since I replaced them, see nothing lower than 11.6v now.
Could be a bad spot on the starter armature, only acts up when the starter is sitting in that spot.
