Popping noise when turning
I am hearing a weird noise when I'm turning or even just going over a bump in the road. It sounds like a pop almost like a the pop of sheet metal??? Is it that the bushings for the cab are worn out? Because the noise is only coming from the drivers side. Any input would be helpful, thank you!
x3 on the fender bolts, I have to snug mine every couple of months. Be careful tho, you can only take up on them so much until... Pop! I'd suggest removing one at a time and putting on some red locktite then snuging them up good..
For those of you who've commented; does anyone know where I can get those captured nuts? Thanks.
97bomber
08-21-2012 06:39 AM
