Not Starting
Not Starting
Hello Community,
My Ford 1995 E-350 short school bus is not starting. When I turn the key and "wait to start," My vehicle says "Engine Temp" and "Water in Fuel."
Any insights on moving forward are greatly appreciated. She is sitting still until some mechanical move is made.
Thank you!!!!
Matthew and Jessi.
Thank you!!!!
Matthew and Jessi.
This is can be a few but simple items, cable corrosion, a bad starter, toasted fender relay, or ignition switch/key issue. Check your battery terminals and clean them up as well as the battery leads. Then check your leads to the starter for corrosion. Its likely a toasted starter or fender relay if your connections are all in check
Go over to the passenger side fender starter RELAY and jump the two large terminals (depicted) with a screwdriver and see if this kick the starter over and in turn cranks the motor, your key will need to be on to get it to fire and continue to run.
Get back to us
jtmalejko
17
06-15-2017 07:04 PM
Midwest Dually
28
02-22-2011 05:53 PM
