Heater Core Test?
First, Take water hoses. put them on each of the nipples of the heater core in the engine compartment. One hose is connected to the faucet and the other hose goes to drain. Turn on water slowly. There should be water coming out of other end. This will determine blockage.
Second, if you can, hook up a couple of lines with a cut off valve on each nipple and a pressure gauge for observation purposes. Fill with compressed air to 5psi and close valves. Watch for 30 minutes. This will determine if the core has any leaks in it.
The sale a "tap into the line" flush kit, easy and cheap. Flush and Fill Radiator Kit at AutoZone.com - Best Flush and Fill Radiator Kit Products for Cars, Trucks & SUVS
Or the 1st way will also work just fine.
Greywolf
1997 - 2003 F150
17
12-04-2014 07:36 PM
jtharvey
08-05-2008 11:07 PM
cougar190
1983 - 2012 Ranger & B-Series
10-16-2007 10:58 PM
