what are you using for ATF?
Just got back from Walmart and couldn't find the Supertech Mercon V on the shelves. I guess I can order it on-line? Also, I'm a fan of the SuperTech line and generally buy it when I can but I have never considered using their ATF. Who do you think makes it for them?
I guess in any case it has to meet specifications.
MaxLife? DEX/MERC ATF : Product Catalog - Valvoline®
I did a fluid and a filter change last year using mark's method. I used a Amsoil Signature ATF made for vehicles that take Mercon and Mercon V. A couple years ago I did the same on my dads 03' but used Motorcraft Mercon V. Obviously the MC Mercon V was a good bit cheaper than the Amsoil. No issues with either ATF as of yet.
The older Dex/merc is no longer approved or licensed by Ford hence the change to MerconV. If you have not changed your filter now would be a good time to do so.
Here's what I have done on every vehicle (auto trans) that I have owned for 30 years....
At 20k miles, I change the filter (due to possible residual/initial wear particulates that may be floating inside) and either drain the torque converter (if so equipped with a plug) or disconnect the trans cooler line at the radiator, fill the pan with fresh fluid, my wife starts the engine and when 2-3 quarts drain into a bucket, she shuts it off, I refill the pan and repeat until the fluid is clear and in case of the f150, 14 quarts of fresh fluid is in.
I change only the fluid after that (unless I determine substances/contamination in the oil). The intervals vary depending on the type of trans, type of fluid and conditions, but in general, every 30k miles. Heat is a killer on automatic trans fluid and when we lived in the desert area, I changed the trans fluid at the end of summer every year.
In regards to filters, oem is fine, but I typically use Wix.
In regards to trans oil, both in sticks and autos I have always used Valvoline.
I have also never had a trans failure in any vehicle I own and typically keep my vehicles for 10+ years, with over 100k on the odometer.
diyster
Escape & Escape Hybrid
06-01-2016 09:54 PM
00 Nav
03-17-2007 06:11 PM
