74 Highboy (The Blue Ghost) goes Cummins
Old 06-14-2016, 01:10 AM
SuperDuty93's Avatar
SuperDuty93
SuperDuty93 is offline
Originally Posted by 4wydnr
Looks like a nice bike! I'm a big Honda atv fan, I grew up riding a Big Red 3 wheeler and before kids spent a lot of time on my 400ex. They run forever.
Yup same. Family has a utility Honda ATV, 2 CT50s and a CT70. They go forever.
Originally Posted by co425
Nice parts and nice little bike.
Eventually I'll do another CB750.
I wouldn't mind one of those either. I love the CB series but dang do they bring some coin these days.
  #47
Old 06-14-2016, 01:14 AM
SuperDuty93
Got a little update. I got a Autoworld cummins mount to try out and review for you all and the company. Its a direct bolt in for the highboy and cummins 5.9 12 valve and 24 valve. Its really beefy! And what I didn't expect was them to include all the hardware as well as angle correction motor mounts and new rubber isolators.
They use a jig to make these and whats cool is that jig is a frame from a highboy that's 100% straight so its supposed to be a guaranteed fit. I have heard nothing but really great things about these guys out of Montana. They are a true 100% American made and operated small town company. Gotta love it.
  #48
Old 06-15-2016, 08:37 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
Sweet build. Subscribed to see the results.
  #49
Old 06-17-2016, 11:39 PM
SuperDuty93
Actually got something done today! I removed the pump and took off the tapped cover and replaced the seal. I then had to replace the pump seal. Very long process and you need to be sure to lock the pump so you don't mess up the timing on the injection pump. I then cleaned and sprayed the area behind the pump with Ford gray engine paint since I wont be able to reach that area later.
Next step will be to give the engine one last really good degreasing and wire brush it to prep for paint. Also going to polish up the injection lines so they look a bit nicer then they do now. Cant stand looking at flaking paint. It either needs to be painted or bare.
  #50
Old 06-18-2016, 03:15 AM
co425's Avatar
co425
co425 is offline
Soda blast your injection lines. They will come out looking almost new.
May want to do your KDP since your cover is off as well.
  #51
Old 06-21-2016, 01:10 AM
SuperDuty93
Yup KDP is on the list to do for sure. And good idea on the soda blast. Ill try it and see how they come out.
Well today I spent 7 hours getting the engine prepped and painted. Wire brushing the engine cleaning every crevice dirt and grease could be hiding took forever. I then took it apart and taped a lot of stuff off and hit it with a few coats of VHT engine enamel. Other then cummins brand rattle cans it seems to be the best at not falling off from heat.
To be safe I hit the exhaust area with super high temp black header paint so if the paint does flake a bit I don't have to see gray flaking and have to be annoyed by how it looks every time I open the hood haha
From this!
To this
  #52
Old 06-21-2016, 08:23 AM
co425's Avatar
co425
co425 is offline
Nice work! Starting to look pretty respectable.
  #53
Old 06-23-2016, 10:58 PM
SuperDuty93
Thanks Brandon After 5 years of dreaming about this build its finally happening.
  #54
Old 06-23-2016, 11:07 PM
SuperDuty93
Last couple days I have been super busy with work but got a little more done to the cummins and of course loads of parts keep showing up. Whats cool is my UPS guy loves cars so he is always hanging out seeing whats going on when he makes a delivery. Which also means he doesnt come to my house at the end of the day
Got my exhaust parts in as well as my steering shaft. The muffler is a jones 4040xl and is the exact same as the aero turbine 4040xl. Owned by jones exhaust but the aero ones are backordered so i went with this one. 4" in and 4" out. Will be a 4" off the turbo and then convert to 5" after it goes through the muffler.
  #55
Old 06-25-2016, 02:56 PM
pgg00's Avatar
pgg00
pgg00 is offline
Should have a nice sound with that exhaust
  #56
Old 07-01-2016, 10:40 PM
SuperDuty93
Yea I hope it sounds good
Update! Was a long week at work so I still need to do final engine assembly. But I got my springs finally and they look good. Should be installing this Sunday and seeing if I can do 37s and not have them look to big.
  #57
Old 07-02-2016, 12:17 PM
co425's Avatar
co425
co425 is offline
Nice springs. Glad it worked out.
  #58
Old 07-02-2016, 02:10 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Subscribed...
  #59
Old 07-11-2016, 12:45 AM
SuperDuty93
Between work I got more done to the truck. I swapped in my kingpin dana 60 and the 14 bolt rear. All painted up and clean.
Also did final assembly on my hx35 with the wicked wheel Going to sound insane!
Also engine assembly is half way done. Will try and finish up the rest tomorrow! Will then test start it and run it for a few minutes on the ground to make sure the timing isn't off.
Saturday 7/16 the old engine comes out and the cummins goes in!! Hopefully I can have it done in 3 days. I have laid everything out so hopefully im not forgetting or missing any parts. I will have to wait 3 days to get the correct length intermediate driveshaft made starting the following Monday. Fingers crossed!
  #60
Old 07-11-2016, 01:03 AM
co425's Avatar
co425
co425 is offline
Nice progress bud! Good luck with the time line.
Quick Reply: 74 Highboy (The Blue Ghost) goes Cummins
