71' - 72' Rag Joint (Steering Coupler) - Replacement?
Old 01-25-2016, 11:15 PM
treverd's Avatar
treverd
treverd is offline
1971 F100 Manual Steering
I know there has been threads on this topic before but I would like to know if any one has had success with a specific manufacture/part number.
From what I've read:
  1. Dorman 31004 has worked for some and not for others
  2. The Napa universial Ford repair kit requires some modification to work
  3. The original C9UZ-3A525A-A is unable to be sourced
Any help is much appreciated.
Also I will be having a local shop (Norfolk, VA) replace my king pins. Is there a recommended vendor?
Thanks Guys,
Trever T
Old 01-25-2016, 11:21 PM
Gembone's Avatar
Gembone
Gembone is offline
I used one from the HELP section of the local Pepboys. It was just the disk. There were 2 size options and the larger one fit my 70 F100. It came with hardware to replace the rivets you have to cut/grind off the original part to replace the disk. Whole deal took about 30 minutes.
Old 01-26-2016, 02:41 AM
greasy rider's Avatar
greasy rider
greasy rider is offline
Is it like this one?
Old 01-26-2016, 06:48 AM
treverd's Avatar
treverd
treverd is offline
I think it once resembled that. Obviously it has seen better days. Just got the truck, so please excuse the massive amount of crud.
Did that part fit on your 1971-1972? What mfg/part number is that?
Old 01-26-2016, 08:33 AM
orich's Avatar
orich
orich is offline
[QUOTE=treverd;15983630]I think it once resembled that. Obviously it has seen better days. Just got the truck, so please excuse the massive amount of crud.
Note in your pictures, I see that the lower steering column shaft tube bearing look like it's in need of repacking. Or worse replacing if left as is the inner bearing flange will be warn away, which could cause a bigger problem while drive.
Orich
Old 01-26-2016, 10:02 PM
treverd's Avatar
treverd
treverd is offline
Orich,
I appreciate you point that out. That will now be change out as well.
Greasy,
Is that part you posted this $111.00 steering coupler from Borgeson? Please tell me that is not my only option?
Borgeson Universal Company :: Vibration Reducers :: OEM Style Rag Joints :: 3/4-30 X 1DD
Old 01-26-2016, 10:52 PM
orich's Avatar
orich
orich is offline
Originally Posted by treverd
Orich,
Greasy,
That clamp will slide down just enough to repack the bearing.
Big job to remove the column to replace the bearing but if it has be done then has to be. The bearing seat flange is just stamped out sheet metal tack welded in place. Those are replaceable from LMC or DC if you don't have their catalog there free online ordering..
Ps the lower & upper bearing are the same if you need replacements.
The bearings are suppose to have a rubber dust boot around them also that dry rots .
Orich
Old 01-27-2016, 08:14 AM
treverd's Avatar
treverd
treverd is offline
Orich,
Here is my upper/lower bearing replacement parts list below. Do you see any thing missing?
I could not find a rag joint on DC or LMC website that is made for a 1971-72.
Old 01-27-2016, 09:15 AM
orich's Avatar
orich
orich is offline
It looks like your list of stuff has a bearings that have been replaced with a sealed type so no need for the black dust boot oem type one.
The flanges have to be spot welded into place, may be even steel pop rivets will hold the lower in.
Orich
Old 01-28-2016, 01:47 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Try these guys for a NOS Ford one.
Mustang Service Center
<table class="static info_table"><tbody><tr><td class="label">Part Number:</td><td>C9UZ-3A525</td><td></td><td class="label">Seller:</td><td>Mustang Service Center - View Profile</td></tr><tr class="even"><td class="label">Description:</td><td>69-73 COUPLING STEERING FORD VAN</td><td></td><td class="label">Phone:</td><td id="phone_primary403733">Show Phone Number</td></tr><tr><td class="label">Price:</td><td>Request Pricing</td><td></td><td class="label">Email:</td><td>Send Seller Email Inquiry</td></tr><tr class="even"><td class="label">Quantity:</td><td>1</td><td></td><td class="label">Location:</td><td>No.Hollywood, California Map & Directions</td></tr></tbody></table>
Old 01-28-2016, 01:51 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
C9UZ3A525A had replaced D3TZ3A525A. Which had replaced C9TZ3A525B. Which had replaced C9TZ3A525A.
This place shows the old number C9TZ3A525B.
Obsolete Reliable Parts
<table class="static info_table"><tbody><tr><td class="label">Part Number:</td><td>C9TZ-3A525-B</td><td></td><td class="label">Seller:</td><td>Obsolete Reliable Parts - View Profile</td></tr><tr class="even"><td class="label">Description:</td><td>COUPLING - STEERING GEAR INPUT SHAFT TO STEERING COLUMN SHAFT</td><td></td><td class="label">Phone:</td><td id="phone_primary844225">(229) 686-5101</td></tr><tr><td class="label">Price:</td><td>Request Pricing</td><td></td><td class="label">Email:</td><td>Send Seller Email Inquiry</td></tr><tr class="even"><td class="label">Quantity:</td><td>1</td><td></td><td class="label">Location:</td><td>Nashville, Georgia Map & Directions</td></tr><tr><td class="label">Part Type:</td><td>NOS</td></tr></tbody></table>
Old 12-19-2021, 03:35 PM
RTT's Avatar
RTT
RTT is offline
Continuted
I have a similar thread posted 12.19.2021
Does anyone know currently where I can buy a correct steering coupler ( Rag- Joint ) for my beloved 1971 F-100, 3 speed manual, column shift ?
Old 12-19-2021, 10:11 PM
RTT's Avatar
RTT
RTT is offline
Hard to Deciper
Would you kindly re-post this ???
Old 12-19-2021, 10:20 PM
RTT's Avatar
RTT
RTT is offline
Rock-Auto states a DORMAN 31004 replaces C9UZ-3A525A. A box appears on the same listing clearly states it is for a 1973-1979 F-100. The photo shows a coupler with threads all around the ring. This may be the one I bought that I am having trouble with proper fitment on my steering gear...........
NOW I see a LARS 202 LISTED as correct steering coupler for a 1971 F-100.......
Old 12-22-2021, 06:41 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Haven Ford in Haven ks shows one C9UZ3A525A.
Haven Ford
620-465-2252
Also these two places:
Parts House Clearance/Grease Monkey Ranch Ltd
Part Number:
C9UZ3A525A
Description:
Steering Shaft Coupler
Price:
Request Pricing
Quantity:
Seller:
Parts House Clearance/Grease Monkey Ranch Ltd View Profile
Phone:
(250) 878-3498
*Tell them you saw it on Rear Counter
Email:
Send Seller a Message
Location
Oroville, Washington Map
Contact Seller to Buy
Basic Listings
Seller in Olathe, Kansas
Part Number:
C9UZ3A525A
Description:
STEERING COUPLER FORD TRUCK
Price:
Request Pricing
Quantity:
Part Type:
Reproduction
Email:
Location
Olathe, Kansas Map
Quick Reply: 71' - 72' Rag Joint (Steering Coupler) - Replacement?
