2006 Expedition random crank but no start
I have a 2006 Ford Expedition with 95,000 miles that has a crank but intermittent no start problem. When it does happen, it will eventually start after one to two tries. I don't have to wait to start it again and I don't have any problems while it is running. Two or three times in the past two months it will sputter out and die (even though I am pressing the gas pedal) right after starting. I'll crank it again and it starts just fine. I have no problems while driving at freeway speeds or around town.
I never had any check engine lights come on so I replaced the battery and the fuel filter. I finally got two codes and replaced the fuel pump driver module and the fuel rail pressure sensor. The codes went off after replacing these two parts. I can hear my fuel pump turn on every time I start the vehicle. I have even taken the entire fuse panel apart to check Relay 303 which is soldered into the circuit board. It is fine and so is every other fuse in the panel. Any suggestions?
jjkoontz
Modular V10 (6.8l)
22
08-15-2019 09:55 AM
Aroberts
11-11-2017 09:12 AM
