Lack of Power in 94 F150 5.0
This might be a stupid question. So my 1994 F150 was driving fine. Then it would stop and not start until it was cool again. It was a pip sensor. (thanks Subford). I replaced the distributor with a new one. I cannot read the timing so I marked everything and put it back with the correct markings. I tried to do the timing by ear. Here is the question
When i just starts up it accelerates ok. Not fast but enough. But when I start driving it a bit, it does not accel well at all. I nearly put the thing to the floor to get it to go anywhere. Also, when I get out of the car it almost smells like it is burning coolant. Now I did flush out the system less that a week ago and it could be some on the engine still but I doubt it.
1. Could it be the timing?
2. Could there be a blown Head Gasket?
3. Is it transmission.
It might be running a little hot. My temp gauge isn't working well. I am looking at fixing that this weekend. This didn't start happening until i changed out the distributor.
It is not currently throwing a code. The codes that are stored are
157: Mass Air Flow Sensor Low Voltage
211: Pip Sensor
332: Insufficient egr flow detected
I know there may be a vacuum leak somewhere, but could this be causing the issues?
Any help would be great.
211: Pip Sensor
on
If it ran fine with good power before you change the distributor than your timing setting is suspect, get yourself a timing light, remove the spout plug to disable computer advance and then set the base timing at the distributor(by rotating it) to 10-12deg BTDC. Tighten down the distributor, reinsert the spout plug and take it for a test drive.
Well, if that is the issue - I dunno - yeah.
The distributor "clock" is wrong, or "off a tooth". If you look at the distributor gear it's helical, so it's not a straight shot to re-install it, takes quite a bit of windage to get everything lined up the way it was.
Line up #1 cylinder at TDC, compression stroke. Observe where the rotor points. Bet it's not the #1 cylinder terminal?
You could move the wires around to make where ever it's pointing now the #1 cylinder. The distributor doesn't care so long as the firing order is maintained. But, the distributor body may not be able to physically rotate enough to reach the proper advance point, vac advance can starts hitting the intake, stuff like that usually.
GiggityBurns
05-07-2018 06:41 PM
sandymane
01-14-2017 08:39 PM
RocketmanVT
12-30-2012 05:04 PM
GSchretter
10-06-2004 02:06 PM
71ranchero500
06-03-2003 02:12 PM
