limited slip rear differentail
01-25-2016, 05:21 PM
on
i have a 2006 fx4. and im about it change the rear differential fluid. i want to know if i have a a limited slip differential.
01-25-2016, 07:45 PM
Will it scratch out both rear wheels at the same time? Has it ever made a shuddering noise when turning a tight circle? With both rear wheels off the ground and turning one, will the other one turn in the same direction? Those are all attributes of a limited slip diff.
01-25-2016, 08:42 PM
there should be a tag on one of the pan cover bolts.......... there should also be a code on the door sticker-- drivers door column.
01-25-2016, 09:39 PM
FX4 '04-'08 all have limted-slip rear diffs. Your axle code should be B6 on the door jamb sticker.
01-26-2016, 09:59 PM
So, bottom line, if you have one, be sure to use the special lubricant plus the Ford additive for quiet, trouble-free operation.
01-27-2016, 09:05 PM
on
My 08 shutters when I take off and turn at the same time. What is the exact name of the additive? Would like to see if that helps
Quote:
Originally Posted by
1saxman
01-28-2016, 08:04 AM
utleylariat08
Genuine Ford Fluid XL-3 Friction Modifier Additive - 4 oz.
01-28-2016, 05:19 PM
You can buy a 7 oz tube of friction modifier at Auto Zone. That's what I have used for years. Cost about $8.
Liv4hockey
1999 to 2016 Super Duty
04-16-2019 04:27 AM
imjwm
20
12-14-2013 01:50 PM
GrizzlyMan660
2004 - 2008 F150
20
02-02-2012 09:15 PM
gappy
08-25-2009 01:37 PM
Rulebreaker
Bronco II
12-05-2004 11:30 PM
