Heavy Miss When Warm
Old 01-25-2016, 03:19 PM
offrdmania's Avatar
offrdmania
offrdmania is offline
92 F150, 5.0 automatic. When the truck is cold first thing in the morning it runs fine. Once it gets up to temp it gets a really bad miss no matter what the temp is outside. It has yet to die though, just runs super rough and doesnt smooth out when accelerating. I dont find any vac leaks and no CEL. Recently got new plugs, wires, cap, coil and the EGR was recently cleaned. Ran fine after parts replacement and then one day it started running rough out of the blue. Any ideas?
Old 01-25-2016, 06:55 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
I'd check what your fuel pressure is doing when it's warmed up. Smooth cold starts, but rough when warm make me think coolant temperature sensor, however. Oxygen sensor is another possibility too.
Old 01-25-2016, 07:14 PM
88XLTLariat's Avatar
88XLTLariat
88XLTLariat is online now
Like Lead Head said, change your O2 sensor. My 88 with 5.0 had the exact symptoms of your truck. I found a Denso O2 sensor on EBay for $19 with free shipping. Removed, replaced, and truck is running good again.
Old 01-25-2016, 09:55 PM
offrdmania's Avatar
offrdmania
Was your truck missing with the bad o2 sensor? Im smelling raw fuel out the pipe so I know all cylinders arent firing
Old 01-25-2016, 11:53 PM
88XLTLariat
Yes, more of a surge. Faulty O2 sensor can cause truck to run too lean or too rich.
Old 01-26-2016, 09:19 AM
offrdmania's Avatar
offrdmania
Mine doesnt surge, it is a definite miss. I can watch the tach jumping up and down when sitting at idle
Old 01-26-2016, 05:10 PM
88XLTLariat
You might check the PIP sensor (stator) in the distributor for faults or the ECM for leaking capacitors. What brand name cap did you install?
Old 01-26-2016, 06:13 PM
phnguyk's Avatar
phnguyk
phnguyk is offline
TPS sensor.
Failing Injector, my '92 was driving me nuts. It was a handful of things. TPS, manifold temp sensor, and two bad injectors.
Old 01-26-2016, 06:38 PM
88XLTLariat
Good call. TPS & IAC would be a good place to start. Easy to test or replace.
annaleigh
01-20-2018 09:59 PM
kylek95
08-22-2014 11:50 PM
Capt17
05-13-2008 10:06 PM
albung
37
03-11-2008 08:07 PM
Quick Reply: Heavy Miss When Warm
