e7te-rb pistons in 96 f150, what are they?!
hello all, just started tearing into my 302 donor motor from a 96 f150, the rods are f2te-ba aq51, and the pistons are e7te-rb. the problem is the truck had rolled, and when they flipped it back over the guy attempted to crank the engine and bent a rod. so i'm needing one rod and piston and am just not sure what type of piston it is, so i'm having a hard time to find one to match. the rods are easy to come by, but trying to figure out what type of piston this is becoming hard... my junk block has different rods (its a 92) which im told are still the same, but i had replaced the pistons with cast ones already, and these pistons look a lil different. they are flat all the way around the bottom, except where the skirts come down, and have a hole underneath through to the wrist pin on both sides of the rod... i just need to know if my cast ones will work, or do i need to find a hyper piston, theyre definately not forged...
thanks!
thanks!
and if anyone knows, do they match the rod and piston from an 01 explorer? i know the rod is the same, the piston looks a little different, and thats the pain, finding a piston that looks the same to compare... cuz i was just gona order one here... http://www.ebay.com/itm/231771894721?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
jamies460
09-01-2007 09:52 PM
LedheadELH
01-30-2007 11:14 AM
76 F150 Ranger XLT
09-10-2004 02:51 PM
